shock recommendation for 69 ranger 2wd
- tpl77
...it has a 351w in it from 1991. It's ready for shocks. Your input is appreciated. If there's anything to increase the stability up front (other than a kit) feel free to offer it. I see a kit in my future, but for now just to put new shocks on the truck should settle it down. It has that trampoline feel right now when you push down on a fender... Thanks!
1969 Ranger, 351W, C6, 2wd
- 390bump
Re: shock recommendation for 69 ranger 2wd
Not a lot of choices. I just ordered some KYBs.. went to shockwarehouse website. Put in code Shock55 for discount..also free shiping
- HIO Silver
... Bilsteins from Shockwarehouse.
Then add a front swaybar from a 75-79 Dentside.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- tpl77
I can't find where the Bilstein shock offers one that fits the truck. Is there part numbers that I could reference for front shocks and rear shocks?
- HIO Silver
The Bilsteins pictured above are the front shocks - Shockwarehouse item #24-184656, Bilstein PN F4-B46-1105-H1
I'm lowering the rear using the spring hanger flip method and have not yet spec'ed shocks for the mod.
- tpl77
..thanks Silver. I went on Bilstein's site and tried to look up the part number, and for a 69 f100 it said not available. I do, however, have disc brakes up front so a PO made the swap at some point. I should be fine. Thanks for your input.
- tpl77
Wow, what a difference. I replaced the front shocks on Saturday and feel a big difference. The shocks I pulled out weren't all that bad, but these are definitely a cut above. I plan to get a sway bar in the future, but for now I'm fine with the way this truck now handles.
- Craigerf100
Hmm I need new shocks. How much did they run you?
1964 F-100 Custom Cab Short Bed
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
1950 F-1 Original 239ci Flat Head V8 SOLD
1995 f-150 4x4 Swb 4.9L 5-speed FORSALE
My Build:
http://www.fordification.com/forum/view ... &sk=t&sd=a
My Build:
- tpl77
...shockwarehouse as shown in the picture from an earlier post... they ran around $90 each. I say it's worth the extra...
