Hello All, I have a 70 bumpside SWB that I am preping for a Crown Vic front end swap. I also have a 93 Mark VIII rear end, but now Im wondering if the crown vic rear end or 03 mustang cobra rear end might be better options.
I would like to end up with the 5.0 crate motor ($12,000) and AOD trans but I am concerned over two issues
1) My concern is the ride difference between the IRS VS the coil- link ?
2) I also have questions about the ability of the crown vic rear or the Mark VIII holding up with the 5.0.
any thoughts?
Crown Vic rear end to go with the Crown Vic front
- Mancar1
Re: Crown Vic rear end to go with the Crown Vic front
Welcome aboard from Gerber, Calif. If you post your concerns/questions in the proper forum I am sure you will get a response from someone who has been there done that. Have fun with your project.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- fireguywtc
Bill
2024 F350 CCSB, darkened bronze
