Which pitman arm for my '72 with 78 front suspension
Deeznuts
Post by Deeznuts »
Guys Im converting the front suspension in my '72 to a '78 disk brake front suspension. We are replacing all the worn out components along with the power steering gear box. I bought a new steering box but the guy at the parts store says they don't offer a replacement pitman arm. That got me wondering, do I use one for a 72 or a 78? Where would I find one? Thanks! derrick
mybros71
Re: Which pitman arm for my '72 with 78 front suspension
Post by mybros71 »
I can't help but wonder what's wrong with the original one. It's not a typical west item unless it was run for a while with a loose sector shaft nut or tie rod nut. Is it damaged? If so I think a wrecking yard might be your best bet.
Tony
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
1971 F100 2wd Prerunner Project (Daughter's)
1971 F250 4wd "The Beast" (Son's)
2007 Toyota Tundra 4wd. (Credit Union's)
Seriously, the best truck I've ever owned, without exception.
Deeznuts
Post by Deeznuts »
I didn't know if there is a difference in the 72 and 78 pitman arms. I bought the front suspension from a junk yard and didn't get the steering box to compare the 2 . Im hoping I can just use my original pitman arm
mybros71
Post by mybros71 »
I'm not sure of the interchangeability. Check the tech articles.
mrsnicks
Post by mrsnicks »
http://www.fordification.com/tech/str-s ... ations.htm
Talks about the pitman arms and shows comparisons there. You will need a pitman arm from the donor (73-up) truck.
"IMPORTANT NOTE: Ford did some redesign of the front end components beginning on late-'71 trucks, including the Pitman arm. If you're installing a disc brake setup on an early-'71 truck or earlier and attempt to use your original steering linkage, you'll might discover that the drag link will not fit the Pitman arm, meaning you'll have to use the steering box (or at least the Pitman arm) from the donor truck. Read the scans at right from the factory Technical Service Bulletins for more info, and scroll down for some side-by-side comparison shots of the variances mentioned in the TSBs.
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
robwymer
Post by robwymer »
Derrick,
F100? Ford started putting discs on F250s in 1968, but didn't put them on the F100 until 1973. Does your truck have power steering already? I put a 73-79 front end on my 67 about 2 years ago - I think it was a 73. Definitely check the tech articles. The guidance there was invaluable. If you don't have power steering,get a power steering pump bracket for your engine. I have a 300 six, and grabbed a bracket off a 1980s van. Consider grabbing the entire front end off of a 73-79 truck (or 68-72 if it has discs), power steering gear included, and simply bolt it onto your truck. That will give you power steering (if you didn't already have it) and disc brakes. You'll also want a power brake conversion if you don't already have it. Don't bother grabbing the brake booster from the donor - I did and had issues adapting it to work with my pedals. I ended up purchasing a brake booster combo kit from Master Power Brakes and it was a perfect bolt-on affair. You may need a shorter steering column, and don't be surprised if parts on the donor setup need replacing, too (kingpins, rotors, etc). I went with a new (1980s style) power steering pump because they aren't that expensive.
Good luck!
Rob
67 F-100 Flareside, 300, Offenhauser 360, Holley 390, Duraspark and MSD ignition, NP-435 4-speed, 3.55 Dana 60, and it will absolutely roast 30" rear tires taking off in 2nd (the one time I tried scared the Bejeezus out of me)
Next engine mod: RV cam (252*)
"They just don't make 'em like they used to."
youngone
Post by youngone »
Rob,
You mean the power brake booster will not work form a 78 in a 72. How about if you were to use the pedals from the 78?
I have a 72 and I am going to use the frontend from a 78 and thought the master cylinder and power booster would fit.
Thanks Pat.
robwymer
Post by robwymer »
Pat,
The brake booster I tried to salvage off the 1973, if I remember correctly, was a larger unit and clearance was a possible issue, even with my 300 six. But I think the main issues were the mounting points not lining up and the brake pedal incompatibility. The Master Power brake booster kit just made everything a lot simpler, and it was a brand new part. I didn't want to try to use the 1973 pedal setup as I viewed that as a fabrication to make another fabrication work better. What can I say, I'm just more comfortable with bolt-on! :thup:
Rob
youngone
Post by youngone »
Rob,
I agree best to use something that bolts on rather than make it fit. Let the engineers do the engineering.
Pat.
