F-350 wheels to a 1976 F-250 2 WD
workingfire
Post by workingfire »
I want to change my F250 to F350 wheels front and rear. Can I install the dual wheels on the rear if I install longer studs? Then can I swap the front hubs to a f350 to use the f350 wheels?
My goal is have the dually look on the f250 that I have now.
Thanks for your help.
jholveck
Re: F-350 wheels to a 1976 F-250 2 WD
Post by jholveck »
I did mine with a little work and some new studs. front adapters are from the 2nd gen dodge 4x4 factory. need a small amount of machining to slide over the hub but works. have to counter sink the inside holes to use lug nuts to center it on there.
jholveck
Post by jholveck »
I used the 72 dually wheels that have the inner and outer dimples to center them. you can use the newer style if you want.
jholveck
Post by jholveck »
it doesn't show much on the rear but it was easy
jholveck
Post by jholveck »
my start..
jholveck
Post by jholveck »
my finished daily driver in 5 weeks..
jholveck
Post by jholveck »
I found a pic of the frame with the dually wheels.
jholveck
Post by jholveck »
now for the good stuff..
72 F350 dually 4x4
3.54 gears in Dana 70
NV5600 6 Speed
93 12 Valve Cummins
78 F250 4x4 power steering box
New a/c unit
Power door locks w/ keyless
Power windows w/ crank handle switches.
Sheepdog
Post by Sheepdog »
Nice looking truck! What size tires are you running in those pics?
1969 F250 4X4
360 V8, C6 auto trans
small lift, 36x12.5x16.5 military tires
