1968 power steering box pitman arm part#
I recently purchased a 1968 f100 2wd just replaced king pins and am converting to power steering found a reman delphi box at napa at a great price. my problem is the pitman arm from the manual box will not fit the delphi box too small. do you have any part numbers or accessability to new or used parts that i can swap with?
- HIO Silver
Re: 1968 power steering box pitman arm part#
The PS gear isn't a good deal if it don't work out for ya.
Did you read the Fordification tech article on PS swaps and the note about the differences btwn early through mid-71 and later pitman arms?
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
