I want better handling
- ivansgreat
Does anyone know how I can make my truck handle like a brand new car. I just don't feel confortable on a two lane hiway. It has a lot of play room in the steering wheel. It may be as much play room as some of y'all have, but i want handling that doesn't make me swerve so much. I have powersteering, but I it's just not enough for me. Any suggestions?
Ivan
1968 F100 2wd
302
1968 F100 2wd
302
re: I want better handling
I'm no expert on front ends but will take a stab here. First, there is an adjustment that can be made on the steering box to remove slop out of the steering shaft to pittman arm shaft if this is loose.
The next thing is to check the I-beam bushings, radius arm bushings, King Pins, tie rod bushings and drag link bushings. Front end components tend to all wear together throughout their life and as they get really bad, the whole front end suffers...esp. the handling. I'm sure others will offer some more advice.
71 F100 302/3.03 Project Truck Underway
- boots
check all that, and if its bad replace it ^^^^^^^^^..
look into a swaybar
look into a swaybar
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- jor
One thing not mentioned that is a big contributor to slop in the steering is the rag joint. They go for around $60 from the usual sources.
jor
jor
- fordfanatic
also try an aftermarket steering stabilizer
Chris
If it's broke, Fix it! If it can't be fixed, explain to your wife that you need it anyway!:D
1971 F100 Ranger parts truck
1969 F100 Ranger parts truck
19?? Combo project (from above)
I've used the one's from the parts house. They worked ok for me.
Just take yer time and make a good job of it. Make sure all the bolts
are in the right way and you might want to use a little "Locktight".
Good Luck Keith
Good Luck Keith
- ~X~
King pins, king pins king pins! Its easy to check: Jack one wheel up and wiggle your tire from the top and bottom. You can see the play around your spindle/I beam area......I know its one of the tougher repairs but it has to be done. If youre running bias ply tires then some radials will help too. 3/4 or 1/2 ton?? Then a store bought alignment
after the steering box adjustment and being sure all the tie rod ends have no slop...the center links do go bad eventually too.
I'll say it too!!!!!!!
King Pin's King Pin's King Pin's Once you do them, nothing seems hard.
But most of the handling prob's on these trucks are caused by old, loose
wobbly kingpins.
wobbly kingpins.
- ivansgreat
Thanks for the info to all. This will definitely be helpful.
Ivan
1968 F100 2wd
302
1968 F100 2wd
302
