Sudden pull to the right
fmfdoc68
Post by fmfdoc68 »
Heya all,
I'm new to the forums here since I'm new to the Ford ownership. I recently purchased a 1968 F250 and have rarely been able to drive it since I've spent most of my time under it or in the engine compartment. I do however have an issue that is a little perplexing and I was looking for some advice from the sages on FORDification. I was having some steering issues with this truck, so I replaced the rag joint, (which went a long way to taking the play out of the steering) and replaced the destroyed front shocks with some LT shocks. The issue that I'm still not able to work out is that during a right handed curve at speeds above 45, I get a significant pull to the right, and immediately have to correct back to the left. This doesn't happen in a slight curve, only when I get into a steeper curve. It feels as if the nose actually drops on the divers side, like the tire may be rolling. I haven't found any play in the wheels with the truck off the ground and I'm at a loss at this point. Any help would be greatly appreciated.
elgemcdlf
Re: Sudden pull to the right
Post by elgemcdlf »
With or without brake usage? Do you have an anti sway bar?
fmfdoc68
Post by fmfdoc68 »
No brakes, running down the road through a right hand curve between 45-60 mph. I don't believe that the twin I beams had an anti-sway bar.
elgemcdlf
Post by elgemcdlf »
These truck are great for body roll. Are your front springs good? If so you might be comparing the old beast to a newer vehicle handling wise. An anti-sway bar will help the truck whether is resolves this issue or not.
fmfdoc68
Post by fmfdoc68 »
Yeah, I guess my next step is to put an anti-sway bar in.
fmfdoc68
Post by fmfdoc68 »
So, for anyone that cares, I took the truck in to get it aligned to see if that would clear up the pull to the right. The mechanic took my keys and put the truck up on the rack. When he came back into the waiting area, he was kind of laughing. He took me into the bay under the lift and showed me all of the bushings that are supposed to be there but are either gone or completely worn down. Guess I'll be swapping out the front end for one with disk brakes.....
ToughOldFord
Post by ToughOldFord »
I was going to say, check the axle bushings....
These can be replace for very little, no reason to change out the brake system unless that's something you feel you need to do.
1969 F250 Ranger Camper Special. 390, NP435, 3:73s.
That government is best which governs least, because its people discipline themselves. -Thomas Jefferson
Craigerf100
Post by Craigerf100 »
yeah but why not switch to front discs :thup: hey fmfdoc, if u do update to disc you will need a new master cylinder and a brake proportioning valve. letting u know incase u didnt :wink:
1964 F-100 Custom Cab Short Bed
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
1950 F-1 Original 239ci Flat Head V8 SOLD
1995 f-150 4x4 Swb 4.9L 5-speed FORSALE
My Build: :fr: http://www.fordification.com/forum/view ... &sk=t&sd=a
flyboy2610
Post by flyboy2610 »
This what my I-beam bushings looked like when removed!
At least I know what made the clunking sound! :lol:
Here's how I did my bushings:
http://www.fordification.com/forum/view ... =a#p624633
Here's how I did the front brake conversion:
http://www.fordification.com/forum/view ... conversion
Here's how Robroy did his front brakes:
Everything but the dust shields and anchor brackets (these are the brackets that actually bolt to the spindles, and the calipers bolt to the anchor brackets) is available off the shelf. If buying new, I would highly recommend getting parts for your year of truck. It makes it much easier to remember what you have, and there are differences in the late/post 72 calipers and those from 68-early 72. You will love the way your truck stops with discs! :thup:
I keep an eye out for F250 bumps with front discs, so I can grab those brackets and dust shields, but there aren't too many of them in the yards anymore.
Good luck! :fr:
