I'm having a hard time finding information on what the big hype is on the Saginaw steering pump. Vs buying a ford pump and not having to customize my lines. Any past experience or information would by great! I'll take poll to make my finally decision.
Thank you
Thanks JP! Ms. Cordova is a factory 1969 Ford F100 Ranger with a 390, Front disc brakes, Cordova copper orange, behind the seat box
The Ford pump, (or "pencil neck" as they're nicknamed) are know to be poor from the shelf. You'll hear more of our trucks power steering squealing with the Ford pump than you'll ever hear Saginaw pumps. I've never personally seen documentation to prove it, but I'd be willing to bet the Saginaw has a lot better pressure, (or volume). It's also a lot less prone to failure.
Jeff http://www.fordification.com/forum/view ... 22&t=46251
basketcase0302 wrote:The Ford pump, (or "pencil neck" as they're nicknamed) are know to be poor from the shelf. You'll hear more of our trucks power steering squealing with the Ford pump than you'll ever hear Saginaw pumps. I've never personally seen documentation to prove it, but I'd be willing to bet the Saginaw has a lot better pressure, (or volume). It's also a lot less prone to failure.
Cool thanks for the info! That helps alot
Yea, you know the Saginaw had to be the better pump since all of the Big 3 car manufacturers used them. Also I have never used a cooler and have never had a problem.
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
I'm running a Ford pump on a 390FE on a 79 steering box and it is a bit underdriven. Meaning, the revs need to come up a touch for full pressure/power steering. It has been working okay since it's a four-speed 4x4. I'm planning on getting aftermarket "Saginaw to FE" brackets in the near future to get rid of the laziness in the steering system.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
GM saginaw steering division has always built the finest pumps. Not sure why they aimed so high, but the Saginaw quality standards are miles ahead of any other automotive steering stuff. That's why they're so good. Ford built pumps suck. The majority of Ford pumps have been Saginaw built since 1997.
There are some good reads online about Saginaw destructive testing of the P style pumps (the canned ham ones most people are thinking about here) where they spin them to unbelievable speeds under crazy pressures and the things just keep going for days, weeks.
I've seen them run without fluid for long periods, months, maybe a year. Dump some of whatever in there and Voila! the power steering works again.
I need some help, so I finished the conversion and my steering is so hard to turn. I did jack the truck up on the first start and turn the wheel back and forth. But when I put it back on the ground it's so hard I can't even turn the wheel. I was kind of thinking I'm not getting enough pressure. Any ideas would be great since I need my truck to go to work on Tuesday. Oh I did notice that my pulley shaft moves in and out so Im not sure if its suppose to do that. Thank you!
Parts
Saginaw pump from a 73 gmc 2500 reman from part store
Ford gear box reman from part store
Cooler
6" pulley
no Xpert here,but I'm sure I heard it took alot of turning the wheels to purge the PS system of air.....not just once or twice. Someone care to chime in on this or explain better.
So I found a article on how to bleed the system. But now when I turn the truck on the steering wheel go's crazy back and forth by it self. I'm at loss. I took the pump back and exchanged it because it did the same thing.
You guys want good laugh I figured out the problem. I accidently switch my lines, I had the pressure connected to the return and vice versa off the gear box. Do you know if this will cause any damage?
jp2005, how is the Saginaw pump doing? How does the truck drive now? How does it feel at highway speeds? I've heard that the Saginaw box feels better at highway speeds. What bracket did you use to mount the pump?
Anthony
1970 F250 Crew Cab 2wd 390/2v short bed
2004 Eddie Bauer Expedition
1955 Chevy 210 4dr Sedan
