Is 20w-50 ok for dana 24
1971ford
Post by 1971ford »
Is 20w-50 ok to run in a dana 24 tcase?
-Ryan
averagef250
Re: Is 20w-50 ok for dana 24
Post by averagef250 »
They have more than their share of problems as it is. Sure it's a great idea to run one on 20wt oil?
1971ford
Post by 1971ford »
Nope, and now that I think about it, it's a terrible idea.
I was thinking more on the 50wt part of the oil, but the t-case won't be getting hot like an engine does...
How about SAE 50? That's what I was looking for but no auto parts store nearby carries it. I can see why though.
What should I run? 75w90 seems a little thick??
-Ryan
Doug Comer
Post by Doug Comer »
Don't quote me on this but I thought it was sae50 that was called for. I could be wrong.
Doug
1967 f100 4x4
1970 f250 4x4
1970 Hi-Boy
Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
Post by 1970 Hi-Boy »
Do NOT use gear oil (75W-90 etc.) in the transfer case, or transmission, (for those still running original 4 speeds). Yes SAE-50 is what is called for, but unfortunately has gone the way of the Studebaker for the most part, and would probably have to be special ordered if found at all. Good news is, 20W-50 is a safe modern substitute to running straight 50 weight motor oil, and gives you a little more all weather adaptability as well, no need to change to a lighter 40 or 30 weight in the cold of winter (as recommended by Ford). Synthetic versions makes it all that much better and will do a better job of lubricating, yielding longer wear and some times even a small gain in MPG's. I've personally been running a synthetic 20W-50 in both transmission and transfer case with no issues to report, and is very nice on those cold mornings everything works as if it were warmer out, no stiffness or sluggish shifting. Save the 75W-90 for your front and rear axles (synthetic gear oil works great as well, and as it lessens friction, it allows more power to reach the ground). Good luck and happy wheeling!
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
71PA_Highboy
Post by 71PA_Highboy »
I just picked up 8 qts of Valvoline SAE 50....
It is out there. I went to Car Quest.
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
