460 engines
Private parties only. No eBay/Craigslist listings.
Finally1
460 engines
Post by Finally1 »
I have 3 460 motors that are good rebuild-able cores .They are complete motors from carb to oil pan (1) is a 1968 Lincoln motor with C8ve heads $500.00 (2) is a 1970 motor with Dove-c heads $500.00 (3) is 1973 motor with the 73 smogger heads $250.00 . May sell the heads separate from the first two as they would be more desirable .
Rick
Re: 460 engines
Post by Rick »
Interested in the 1970 460 engine, are you sure it is a 460 and not a 429? Is the metal factory tag still attached to the coil bracket, if so, what are the numbers stamped on it. What was the engine originally installed in? Has the engine ever been apart? Are all the accessories still mounted on the engine? Thanks for taking time to answer my questions.
michael69
Re: 460 engines
Post by michael69 »
PM sent
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
Finally1
Re: 460 engines
Post by Finally1 »
Not sure what the motor came from . My uncle had a pulling tractor a few years ago and this is the last of the motors he had for back up . I will check to see if the tag is still on it .
Rick
Re: 460 engines
Post by Rick »
Still intersted in the 1970 460, does the engine turn over, do you think it has ever been apart? Thanks
Finally1
Re: 460 engines
Post by Finally1 »
The 70 short block was sold Saturday . The stuff belongs to my cousin and he posted a add on craigslist .
