dana 44
- BRUTUS_T_HOG
dana 44
will a dana 44 from a 72 directly replace the 44 i have in my 69? just found one for $100, this would save me several hundred dollars
ASE Certified Technician
- Wes
Re: dana 44
it will bolt in, the gear ratio might be different then there are low pinion and high pinion the drive shafts are different lengths. If you do swap low pinion for low pinion or vise verse no problem.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
- BRUTUS_T_HOG
Re: dana 44
ok its a low pinion just like i have. he said the ratio was 4.09, i don't exactly know how he got this information he said the ID tag was missing and mentioned counting the gear teeth, so he might have done the math and came up with 4.09 but dana just rounds up to 4.10? i have 4.10's i believe, its been a while since i looked
- BRUTUS_T_HOG
Re: dana 44
yeah since i never use 4wd on a solid surface that 2wd can handle. would it come from the factory as a 4.09 up front and 4.10 rear?
- BRUTUS_T_HOG
Re: dana 44
ok so he got me a picture of the ID tag. it clearly says 4.09 with an axle code of d31a-ga. bill of material code 603395-1. i looked it up and it appears to be from a 1973-1975 f-250.
will this still work?
Re: dana 44
It should, I'm sure someone will have a more definate answer for you.
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- 71PA_Highboy
Re: dana 44
Brutus,
It is from an F250. Do you have an F250.
If the anwser is yes, then yes it will work, if no, then it will not.
you will have to make some changes regarding the brake hoses.
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- averagef250
Re: dana 44
Yes, our trucks were 4.09 front, 4.10 rear. Unless you had an old low pinion 60 front then you got 4.10/4.10.
- BRUTUS_T_HOG
Re: dana 44
ok i verified my current ratio is 4.09, i just want to be sure this axle will fit perfectly when i drive 5hrs round trip to go get it. if there is no difference then why would the BOM code say its from a 73-75 and not a 67-75? there must be some kind of difference
- averagef250
Re: dana 44
Yeah, the difference is the YEAR IT WAS MADE!!!!! They are all the same.
- BRUTUS_T_HOG
Re: dana 44
ok thanks guys. i was just trying to be sure. i just noticed you are from portlandish.. which is exactly where im heading to go pick up this axle. funny
- 71PA_Highboy
Re: dana 44
I still haven't understood if you have an F100 or F250.
Got Ford?
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- BRUTUS_T_HOG
Re: dana 44
i guess i never mentioned that, i have an F250. i already picked the axle up.
