wet feet! and insulation too...
Wondered if anyone out there would know the cause of water intrusion into the cab during rain? I checked the evap. hoses on the A/C and the heater core is not leaking. OBTW, the water came from just sitting in the rain, not by way of forced intrusion, like driving in rain. Any help or ideas are welcomed. Thanks.
1968 F-250 Camper Special Ranger 16769 Original miles
- Heathcliff68f100
Re: wet feet! and insulation too...
rust holes in the celing?
, maby you left the windows down, or have bad windshield rubber, mine leaks too but its no biggie, i dont have carpet, or rubber, just a metal floor
1989 dodge b250 van, 239 v6 blown a904 tranny RIP
1968 ford f100 lwb l6 240 c6 tranny
- basketcase0302
happycamper,
Maybe try a water hose test of the following:
Windshield wiper pivot gaskets
Hood to cowl gasket
Steering column to firewall gasket
Clutch rod gasket
Cab light gaskets
Windshielg gasket
Rear window gasket
Have someone spray around those areas, while you're in the truck with a flashlight.
Hope it helps.
Hood to cowl gasket
Clutch rod gasket
Cab light gaskets
Windshielg gasket
Rear window gasket
Hope it helps.
Thanks for the replies. We are going to give 'er the water test with the hose and flashlight and see what turns up.
windshield wiper pivot gaskets is usually the place they leak at.
- flyboy2610
I put new cowl lacing on mine, then ran a bead of clear silicon caulk along the back edge of it. No more leaks.
Someone put a piece of door weatherstripping along the back edge of the hood. They said it works really well.
- Doug F
I did the hose test and saw that my wiper gaskets leak... Someone should do a "how to" on it.
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
http://www.pinheadlounge.com/Pinecone
https://www.facebook.com/PineconeDesign
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
its as easy as replacing a gasket with another gasket. i have read where some have just used a silicone or something like that to keep it from leaking there.
- basketcase0302
Doug, please no....I'm looking at mine. And have the new gaskets, (just not the time to do it)!Someone should do a "how to" on it.
1) Pull the glove box out
2) Pull the stereo out
3) Pull the heater controls out
4) Pull the wiper blades out
5) Unbolt the wiper linkage
4) stand on your head for an hour
I'm procrastanating again...
- Doug F
HAhaha... I guess I am a little different! My truck is pulled all apart and I could see where it was leaking very easy. Since it is apart, I am fixing the rust, cleaning out all body seams and filling them with POR15 and am going to replace the floor pans.
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
