Fuel gauge
Fuel gauge
What gauges will work with our fuel tank sending unit? I read the article, does any know any off the top of their head?
Re: Fuel gauge
any gauge should work...provided it's calibrated for the sender. Remember, most aftermarket fuel gauges are set up for the General, which is almost exact opposite of how our stuff works
- knightfire83
Re: Fuel gauge
For use with a Ford sending unit, it needs to be a gauge with the range 73 ohm empty - 10 ohm full.
Summit has a good selection: http://www.summitracing.com/search/Depa ... s=Rank|Asc
1974 Ford F-100 4x4- 360 / manual.
1970 Ford F250 4x4 ~ Sold.
Re: Fuel gauge
But will all of them match up in the middle too? Like at quarters and half?
- 70_F100
Re: Fuel gauge
Any fuel gauge is going to give you only a "relative" indication of how much fuel is in your tank.JMcTurnan wrote:But will all of them match up in the middle too? Like at quarters and half?
If the upper and lower resistance limits are correct on the sender, the "in-between" will be as "correct" as possible.
If the gauge itself is correct for the upper and lower limits on the sender, it, too, will be as correct as possible.
The keyword here is "relative". Remember, as you're driving, the fuel will be sloshing around, and no matter how "accurate" your fuel gauge is, it's not going to tell you how many gallons are in the tank. Full and empty are the only REALLY close readings, and that's only if the travel of the gauge is 100% calibrated.
That's not an oil leak
Re: Fuel gauge
So relative, I understand that. It won't be anywhere near exact. But not like I'm going to run out of gas when i had 3/4.
- 70_F100
Re: Fuel gauge
Re: Fuel gauge
i think as long as you get one with the correct ohm values you will be ok.
