Paint color
- TNIceWolf
Paint color
Does anyone know the particular shade of silver color paint that was used on the 70 and up intrument cluster bezels was? Clues as where to get an acceptable matching type? The common chrome finish paint I see for sale just seems a bit too bright.
Presently in the stable
1969 Ford F-350 DRW
1969 Ford F-350 DRW
- TNIceWolf
Re: Paint color
ahhhhhh..........that is actually a name i seem to recall on here from somewhere........thanks Craig
1969 Ford F-350 DRW
1969 Ford F-350 DRW
Re: Paint color
yea i actually repainted my 67 cluster with the chrome paint. and it was not as shiny as the original. i had a run i had to sand out of it. and when i did it. the color underneath was shiner than the chrome paint i used.
- TNIceWolf
Re: Paint color
I went and checked out the paint color online......what i mostly came up with was a wheel paint color......does that sound right?
1969 Ford F-350 DRW
1969 Ford F-350 DRW
- michael69
Re: Paint color
Yes, you will find the argent silver to be wheel paint also because that is the color of alot of chevy ralley wheels. Its most likely the closest match you will find.
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
- papabug71
Re: Paint color
Arget was also used on alot of trim pieces. The big one that comes to mind is the grill. All the silver stuff on the 70+ grills is argent silver.
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
- Joe Kriston
Re: Paint color
You guys are losing me...I thought the instrument cluster bezel was a chromed plastic---certainly brighter than argent silver---with a black or wood grained accent...
- TNIceWolf
Re: Paint color
Joe Kriston. Here is a pic of the current dash cluster in my truck. It is a 69 so it is metal instead of plastic like the one I pulled from a 70 Custom.but the colors are identical.
The reason I am trying to get the closest match is because the 70 cluster needs refinished because it is worn down to the base yellow plastic in places and the fact that I just purchased an F-600 cluster for use in my 69. That panel is just a plain white and I want to use the silver to sort of make the gauge trim rings and such stand out and all match when I add the vacum gauge....several switches, a new electronic tach and refinish the bezel face in a burlwood veneer.
1969 Ford F-350 DRW
1969 Ford F-350 DRW
- papabug71
Re: Paint color
The 70' & up gauge bezels had both the chrome & silver. I think the chrome is actually mylar film.
Matt
Mine since 5/7/'94
- TNIceWolf
Re: Paint color
Drat it!! Now I have to research Mylar film as well. Knowing my luck it wont work on metal.
1969 Ford F-350 DRW
1969 Ford F-350 DRW
- 70_F100
Re: Paint color
It wasn't mylar film. It was chrome plated. Mylar film would peel off, rather than wear off.TNIceWolf wrote:Drat it!! Now I have to research Mylar film as well. Knowing my luck it wont work on metal.
Mylar film, however, might be an option. It's nothing but a thin tape with a chrome finish applied to the back side.
The best example I know is packaging tape, the thin clear stuff.
That's not an oil leak
- papabug71
Re: Paint color
I must be thinking of the door panels. They had the chrome trim that would peel off.
Matt
Mine since 5/7/'94
- 70_F100
Re: Paint color
TELL me about it!!!!!!!!!!!!papabug71 wrote:I must be thinking of the door panels. They had the chrome trim that would peel off.
- flyboy2610
Re: Paint color
Base model trucks had the all metal instrument cluster without the center bar. Higher end trim packages got the center bar type clusters. If you come across a good all metal cluster, you might want to grab it. I have seen people on here looking for those before.
