door seals
71murd
door seals
Post by 71murd »
any help would be a great help its been 7 years since i took it apartvery close to putting a 68 m-100 back on the road
67MercM100
Re: door seals
Post by 67MercM100 »
Kewl! Another Merc gettin' back on the road. What parts n pieces are you having difficulty with?
Re: door seals
to put the door seal on you use wether strip adhesive. the two ends of the seal go under the door seal plate.
71murd
Re: door seals
Post by 71murd »
on the bottom trere is no pinch weld or ridge like rest of door frame any pics would help
Re: door seals
pic of what exactly? the seam in the rubber?
71murd
Re: door seals
Post by 71murd »
do you open up that slot so it lyes flat and door sill screws over it
flyboy2610
Re: door seals
Post by flyboy2610 »
71murd wrote:do you open up that slot so it lyes flat and door sill screws over it
Yes. It follows the edge of the door, with the round seal edge on the outside, just like the rest of the door frame. The slotted part part just lies flay, and the door sill screws down over it.
MAK
Re: door seals
Post by MAK »
Like Flyboy says, the single layer of rubber that "clamps" the pinch weld around the inside top and sides of the door opening is rolled out flat along the floor and the carpet and sill plates go down over it. You might be able to see how it works in some of my pics here:
http://myphotopile.com/Public/F100/slides/IMG_8598.html
Re: door seals
here is one i just took with my sill plate off.
