67 doors and 68-72 door panels
since i want the 67 doors on my 71 but have a great set of door panels i have decide to combine the both. i looked at aech over a couple of hours and have decided that is waht i will do. the main reason is because the doors on the 71 have creases in the bump. i will make some cardboard cut out as to make all the right hole and such and fill in what doesn't need to be used. it will be a big mod but should look really good if i can make it a reality.
Re: 67 doors and 68-72 door panels
let me know if this works for you, I have a 67 and really like the door handles but the new doors I am getting are from a 72. I hope I can take the door handle and latch system and install it in the 72 doors without having to cut and weld the inner door.
the 67 door
the 68-72 door
this operatign probably wotn work. because the work is too hard to do. the only easy way would be to cut the center section out of each door and swap them.
the 68-72 door
