speedo gear
shortbedCUSTOM
speedo gear
Post by shortbedCUSTOM »
where can I get a new speedo gear? the one at the end of the speedo cable that is inserted into the tranny. the one I just pulled out is stripped. it's yellow with 18 teeth.
also, I'm assuming that it was the wrong one because my speedo showed 77mph eventhough I was travelling at 70mph. which one do you guys think I need?
Carlos
re: speedo gear
flyboy2610
re: speedo gear
Post by flyboy2610 »
Your speedo is running 10% fast.
70 divided by 10 is 7. 70+7=77, which is what your speedo is showing.
And it's not wise for your speedo to be showing too much! :eek:
What you need is a speedo gear with 10% MORE teeth, so it turns slower by 10%
18 (number of current teeth) didvided by ten is 1.8. The closest you will get is a 20 tooth gear, so that's what you need.
I know NPD sells them, also.
http://www.nationalpartsdepot.com/
re: speedo gear
There's a guy on E-bay selling a few assorted speedo gears, but his auctions are due to end within the next few hours, so....
http://motors.search.ebay.com/_W0QQsass ... rtspackrat
shortbedCUSTOM
Re: re: speedo gear
flyboy2610 wrote:Your speedo is running 10% fast.
thanks, that is what I thought. I'm ordering it first thing tomorrow morning. :)
shortbedCUSTOM
re: speedo gear
ok, I have since swapped my four speed with a Tremec 5 speed. I installed the speedo gear that I had for the Tremec and now it shows 60mph when I'm traveling 70mph. which one do I need?
crazy larry
re: speedo gear
Post by crazy larry »
I got a brand new one at my Ford dealer. who'd a thunk? and this was a couple of years ago, not twenty.....
Larry
'72 F-250 Kustom 396 c.i.
Fotoes
flyboy2610
Re: re: speedo gear
shortbedCUSTOM wrote:ok, I have since swapped my four speed with a Tremec 5 speed. I installed the speedo gear that I had for the Tremec and now it shows 60mph when I'm traveling 70mph. which one do I need?
The current gear has 20 teeth, is that correct?
A gear with 20% fewer teeth would be a 16 tooth gear, and should show a reading of 72mph when you're doing 70. That's pretty close.
shortbedCUSTOM
re: speedo gear
sorry, the one that is in there has 23 teeth.
flyboy2610
re: speedo gear
If you can get a 19 tooth gear for that it should show 69mph at a true speed of 70mph. That would be real close.
