Overdrive Transmission Cross Reference Table
Chasbod
Post by Chasbod »
I would buy someone dinner (Whataburger ok?) if they could come up with a Table that listed the various overdrive transmissions we can use on our trucks (by engine) and what to expect when installing such as: Stock bell housing, aftermarket, or integrated?, spacing adaptor needed for input shaft? Cross member mods needed? Driveshaft mods needed? Removable transmission hump needed for clearance? What year trucks/vehicles that have the donor trannies, etc.
I'm trying to piece this info together but way too many holes in the info.
Thanks
71 F100 302/3.03 Project Truck Underway
binder56jd
Re: Overdrive Transmission Cross Reference Table
Post by binder56jd »
i think that might be worth more than a dbl w/cheese :wink: btw--r u old enough to merember the Mel Tillis wha-wha-what-a-burger commercials???
now back to your regular programming :D
now serving #235
mmerlinn
Post by mmerlinn »
Sounds like a good idea, but there are so many cockamamie combinations between Ford motors and transmissions that the chart would probably cover your living room floor.
mmerlinn (http://mmerlinn.com/catalog/makeridx.htm)
"People who are careless and sloppy writers are usually also careless and sloppy at thinking. Answering questions for careless and sloppy thinkers is not rewarding." - Eric Steven Raymond
willowbilly3
Post by willowbilly3 »
Theoretically if you have a small block or 300 then you can make any other small block tranny work (except very early 5 bolt bell housing). Be most aware of balance issues and what fits what in that regard.
The only overdrive that came on an FE was the T85 3 speed with overdrive. There are threads on installing the nv4500 from a gas Dodge. I guess they are ok but for all the expense and hassle I wouldn't. I just drove one on a V10 and the 3-4 split is horrid. You have to really wind out to make the shift and still be anywhere near the powerband.
