Torque Converter Whine & Vaccum Leak Sound
FordTruck
Post by FordTruck »
I went under my truck while it was running and my tranny whine is coming from my torgue converter and was wondering what could cause that?? It dosen't seem to affect the shifting or going into gear of the tranny but it still bothers me since I'm gonna be driving the truck daily soon. So any help why or how I may be able to fix it without too much work or $$$? Thanks for help :fr: Oooh I guess I should say its a C6.
Also when the truck gets warmed up after driving it around the block a few times theres also a noise that sounds like a vaccum leak but I've checked the vaccum line running to the tranny and it isn't leaking. It usually olny makes that noise when it just ideling when I give it gas it seems to stop. I just hope the tranny isn't going out :roll:
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
Banjo
Re: Torque Converter Whine & Vaccum Leak Sound
Post by Banjo »
you sure you not hearing power steering whine? my 68 will be kinda noisy running if the front wheels aren't perfectly straight.
FordTruck
Post by FordTruck »
It can't be that because I don't have power steering :lol: but thanks for the imput.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
My427stang
Post by My427stang »
I put a Chevy ZZ4 in a 56 Chevy about 8 yrs ago and had a funny thing happen
I had a PCV but no breather on the other side, it would do the same thing
We even had the tranny out, turns out it was vacuum pulling by the rear main making a whistle.
Not sure if yours has a PCV without a breather on the other valve cover, but if it did, theres a place to look
FordTruck
Post by FordTruck »
I'll try that because the orignal valve covers had a PVC in them and the I put some after marker ones on that have a place for them but I lost the PVC valve so I just stuck the hose in the hole on the valve cover.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
spartman
Post by spartman »
If the whine is truly coming from the tranny it could be that the torque converter bearings are bad.
I had a mercury that I rebuilt the tranny on and didnt replace the torque converter and a little while after driving it I had a whine in mine.
Turns out it was the torque converter.
Something to think about.
FordTruck
Post by FordTruck »
spartman wrote:If the whine is truly coming from the tranny it could be that the torque converter bearings are bad.
Did you still drive it anyways?? How long did it take till it when out?? My dads gonna be parting out his van soon and its got the same tranny as the one in my truck so I'm gonna keep it for a back up incase this one does bite the dust.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
spartman
Post by spartman »
I kept driving it till the engine died.
Probably put another couple thousand miles on it.
FordTruck
Post by FordTruck »
Sweet!! All it has to hold up to is driving to school everyday about 15mi a day so it should hold together for that.
Its bein an up hill battle with my dad with anything involving my 70 and I thought this might be the last nail in the cofifn as far as convincing him its ready to use as my daily driver. He dosen't have as much faith in my truck as I do :lol:
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
That 'vaccum leak sound' might be just the air going into the carb. It's usually a lot louder when the air filter is off or you're using an open-element filter. (You ARE using an air filter, right?)
If you've got power brakes, you might want to check the line going to the booster for leaks, or the booster itself.
FordTruck
Post by FordTruck »
Is this where my PCV valve is suppose to go??
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
yes thats it.
binder56jd
Post by binder56jd »
My427stang wrote:I put a Chevy ZZ4 in a 56 Chevy about 8 yrs ago and had a funny thing happen
improper crankcase ventilation can cause all sorts of mystery ailments
http://www.burtonpower.com/technical_1/ ... ystem.aspx
now serving #235
