If you are just wanting to replace the bezel...
You can pull the instrumentation from your existing bezel and swap it with the new one...
That doesn't change any wires or functions, just the outter bezel which is what most folks wanna do 'cause theirs is faded out.
If you do need to replace everything, make sure you get the right kind... if you have lights you don't wanna swap it for one with gauges unless you wanna run some new wires.
KaptnKA
S
