Brake Pedal Height
- 390F100
Brake Pedal Height
Does anyone know the height the brake pedal is supposed to be at because I installed my new booster/master combo with bracket and it pulls the pedal way down for the rod to connect to it. It just doesnt seem right to me???
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
2007 Suzuki S40 650
- Hawkrod
Re: Brake Pedal Height
Sounds like you may have a late model booster. I made that mistake a while back and found out that 77-79 can have a different length rod and the trucks have different brake pedals. I put a 78 booster on my 76 and the pedal was too close to the floor. Had to change the stupid pedal to fix it. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- kaptnkaos
Hey Hawkrod..
Could he swap a PB plunger rod from a bump with the newer MC ???
I had to swap the plunger rod on my manual MC for a power one when I did the PB upgrade on my '68 CS...
KaptnKA
S
KaptnKA
- Hawkrod
There is no plunger rod on a PB master cylinder, it is part of the booster and does not come apart unless you have a linkage style booster and then you can just make a new arm. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
