40 20 40 seat
40 20 40 seat
Just picked up 68 250 and seat is shot. I have a nice 40 20 40 seat from a 97 anyone installed one and if you did did you gain steering wheel clearance or loose it. I also have vinyl bench from 93 F350. Which would give me most gut clearance. Big guy in little truck.
1968 F250 Camper Special 390
1964 Galaxie hardtop 352
1967 Cougar project
1993 F350 Crew cab 5.8
1988 Bronco 5.8 C6
1966 Mustang fast back project
New 1962 Falcon Gasser project
1967 Cougar project
1988 Bronco 5.8 C6
re: 40 20 40 seat
The '93 will be a bolt-in procedure using your existing brackets. After removing the tracks from your donor seat you'll have to drill out the threads on the seat frame so the studs on the older tracks can go up into the holes and be secured with a nut.
You'll have to fabricate brackets to install the '97 seat.
Check out this link:
http://www.fordification.com/seats.htm
- flyboy2610
If your truck has power steering, an aftermarket wheel will gain you some belly clearance.
Worked for me!
Worked for me!
It appears as if he's already done that:flyboy2610 wrote:If your truck has power steering, an aftermarket wheel will gain you some belly clearance.
Worked for me!
http://www.fordification.com/forum/view ... 841#328841
- Joshpow
re: 40 20 40 seat
Some of us gotta have all the belly room we can get to be comfortable. My new seat helped me some too.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
re: 40 20 40 seat
Great, that was the answer I was looking for!
1967 Cougar project
1988 Bronco 5.8 C6
1967 Cougar project
1988 Bronco 5.8 C6
- FLATBEDFORD
Re: re: 40 20 40 seat
'97 F350 is same generation as '96. F250/350s didn't change 'til '98. It should still be easy.FORDification wrote:.........You'll have to fabricate brackets to install the '97 seat.
My Photo Gallery
My Photo Gallery
- HayHauler
all i had to do was put some 1" blocks in the corners where the bolt holes are. I did this about 5 years ago and havent had any issues with it. i took some crap from my friends over what i paid for the seat (500) but it was well worth it to me. took bout 30 min to install and drastically changed the interior, probably the smartest mod ive done. ill try to get some more pics up
No problem can withstand the assault of sustained thinking. -- Voltaire
- HayHauler
