How do you get the axle out 1969?
jumpinjivinjoe
Post by jumpinjivinjoe »
I just got a 1969 Ford f-250 for $600. I need to replace the rear brake shoes, and in order to do that I have to remove the axle. It's a Dana 60. How do remove the axle? My three jaw puller will not pull it off. What do I need to do? In my manual it says "If tapered dowels are installed in the axle shaft flange, place a drift in the center of the flange and strike it sharply to loosen the dowels." What dowels are they talking about?
19674x4
Post by 19674x4 »
what they are talking about are cone shaped washers that are inside the channels for the bolts that hold the axle tothe hub. You can try and hit it with a hammer around the axle head. to loosen them, or you can tr and pry it loose and wiggle it out with a big flathead screwdriver. lube it up with wd or pb blaster. if you can get a small screw river or centerpunch on the split in one of the coes you might be able to spin it out or at least enough to loosen it.
My Photo Album
heep70
Post by heep70 »
Try placing a pipe or socket that is bigger on the ID over the cone washers onto the face of the axle flange and smack it with a hammer.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
jumpinjivinjoe
re: How do you get the axle out 1969?
I wacked the studs. Now I got the axle out. I just need to get a socket big enough to fit on the wheel bearing lock nut. Thank you for the help so far. :D
1957 Mercury Monterey
1936 Dodge coupe
1969 Ford F-250 (360)
heep70
Post by heep70 »
:thup:
Greg
oldschoolrods
Post by oldschoolrods »
When you put it back together put some anti-sieze on them incase you have to take it back apart :thup:
1969 Ford F250 Custom Cab 360/C6 - currently under de-construction
