ill call it the turbo defroster 3000
heres the plan. since all of you know that our bump's defrosters only open up a small window of clear windsheild, im hoping by adding the turbo defroster 3000 that it will blow heat with more force into the windsheild where it will kindof spread. thats all in my mind though
so here is the beginnings.
ingredients:
-normal defroster hoses
-2 Computer fans
-proper turbo3000 adapter plates
opening in dash:
a computer fan's actuall fan's circumfrence matches almost perfectly with the dash's defroster whole.
Mount A:
for the fan to connect to the bottom of the dash, i can create some pretty simple mounts at my work (welding shop
Mount B:
i can cut a large whole in a plate that fits the Groove on the defroster hose just like it would be if it was connected straight to the dash.
it will have a little spacer to prevent the fan from ever touching the hose and it will simply mount to the 4 fan holes.
am i crazy?? or will this work
what do you think?
