9" swap question
iamthewreckingcrew
9" swap question
Post by iamthewreckingcrew »
Can I take the 9" pumpkin out of my 81 and swap it right into my 68 9"?
The 81 has traclock and the 68 is an open rear. I want to roast both rear tires when I swap in the big block.
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
no because the spline count on the axles are different in 67-72 vs newer trucks. the 67-72's mostly had 28 splined axels. very few of them had 31 splined axels.
iamthewreckingcrew
re: 9" swap question
Crap. And I suppose the axles in the 81 are too long too, huh?
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
probably. but you could sawp the whole rear end if you move the spring perches on the axel housing.
F100builder
Post by F100builder »
If you have the $$$, you can do the swap and buy new axles with any spline and length you want. I've seen axles for a little as a couple hundred for the pair.
Patrick
