So yesterday i attempted to remove my wiper motor... i removed 3 bolts and a hat nut, i can feel what appears to be some kind of clip but i can't get the bugger off.
I was wondering if any body can post a picture of the assembly, it seems someone said they had some out. I dont want to remove whole assembly if i can avoid it, since i would probably have to remove heater and all vent hoses to get it out.
thanks David
wiper motor clip?
wiper motor clip?
67 F100 240 I6 3spd now gone
1971 F250 LWB FE power by FORD
re: wiper motor clip?
well i finally got bugger off, and didn't break it. here is a picture of it.
http://s255.photobucket.com/albums/hh14 ... 1_1554.jpg
so here's how to remove it; 1: get a little screwdriver up under the flap pry it up just a bit, the tab that keeps it from sliding is about 1/8 " 2: slide it over and lift it off, you're done it will fall right off. just wiggle arms loose remove motor. YAY i did it
- seattle67
no problem... i tried pulling it every which way... when i got it finally i saw that if i had known what it looked like, and how to remove it, i could have had it out in 5 minutes.(after getting bolts out that is)
So I thought i'd share what i learned.
