Cleaning Aluminum Wheels
- kentdaryl
Does anybody have a good suggestion on cleaning up aluminum wheels? I picked up a set of old slotted aluminum wheels and need to clean the machined (smooth) surfaces as well as the rougher cast surface. Any ideas besides a toothbrush and elbow grease?
- l1k2gadd
My daughter used Mother's aluminum polish on some parts on a 1989 Full Sized 4x4 Bronco that was her first vehicle for getting around in school. It did require bit of elbow-grease but the results were amazing.
Too many projects, too little time, but.. lovin' it!
2-1966 Mustangs (one 289-2V and one 200 6 Cylinder),
1-1990 7-Up 5.0 Mustang LX Convertible (second one),
1-1990 7-Up 5.0 Mustang LX Convertible (third one, for parts only)
1-1990 7-Up 5.0 Mustang LX Convertible (fourth one, best of the bunch).
1-1992 "FEATURE" 5.0 Mustang LX Convertible (only one)
1-1993 "FEATURE" 5.0 Mustang LX Convertible (one of the yellow ones)
- seattle67
re: Cleaning Aluminum Wheels
Yup, Mothers is pretty amazing, but no way around the elbow grease that I know of.
Dan
- kentdaryl
Re: re: Cleaning Aluminum Wheels
Is it just Mothers aluminum polish or what?seattle67 wrote:Yup, Mothers is pretty amazing, but no way around the elbow grease that I know of.
- kaptnkaos
Another good aluminum or chrome polish is called "Never-Dull".
It comes in a silver can and you can get it Wal~Mart.
I got turned onto the stuff by our Uncle Sam... and swear by it.
It's polish inpregnated cotton batting.
You just tear a chunk of it outta the can, the stuff really works great...
It still requires manual labor but it works better that just about any thing else I've tried.
I'm sure a guy could come up with a way to attach it to a drill motor like one of those Mothers cleaning balls.
KaptnKA
S
KaptnKA
- l1k2gadd
In regard to Mother's here is a picture and I used a quarter so you can see about how big the container is.
Fordman, steel wool is absolutely fantastic for cleaning chrome parts. It does away with a lot of small rust lines and specks on bumpers, wheels, mirrors and all kinds of chrome. ONLY use 0000 (Four Zeros) gauge steel wool on chrome on your vehicle. Anything coarser than this will scratch chrome!! I was told by some old-timers in the 80s about the 0000 steel wool and I have used it on all kinds of things. My daughter used it on the Styled Steel Mustang wheels we bought from a local e-Bay seller right here in town about 3 or 4 years ago. It did a great job on them! The 0000 should clearly be labeled on the package. Along with the 0000 it may also say very fine, but unless it shows 0000 I will not buy it.
Aaa-h-h-h-h, yes! What did we ever do before there were digital cameras?
- FoMoCo
For the rough area, a scrurb brush and Eagle One acid based cleaner simply called mag cleaner. It has a picture of your wheels on the bottle. For the shiny edge part I'd use 600 grit sandpaper.
Nick
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
- kentdaryl
Thanks for the suggestions. I'll try the Eagle mag cleaner for the rough areas and start with the Mothers on the smooth areas. The smooth areas aren't the worst part, hopefully the Mothers polish will take care of that, the rough areas are the problem. I'll let you guys know how it worked.
