My 240 six is gone and my 390 will soon go in. As you can see in the picture, I have also installed a PS box to replace my manual one. When I read the tutorial on installing PS, I noticed it said that the PS box would interfere with the Driver side engine tower. Mine does not.
Do I have to move the engine tower back to install the FE motor?
Engine tower question
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
1989 Ford F150
re: Engine tower question
Yes, for an FE the perch should be mounted in the rear set of holes, which will cause interference with the PS pump, meaning you'll either have to find the correct offset PS perch (preferred), or grind a notch in your existing MS perch.
Anyone got a PS FE perch out there then?
1989 Ford F150
1989 Ford F150
