brake assembly
jguajardotx
brake assembly
Post by jguajardotx »
I am converting my 67 3 speed to an automatic shift on the column. I installed a brake "only" assembley today to get rid of the clutch pedal. The new assembly is from a 68-72 not sure, anyways the push rod comming from the master cylinder is to short. The brake pedal is dam near touching the cab floor. Do I need a m/c from a 68-72 now??
Heeeeelp!!!! :?
Camel Ciggarettes,John Deere and Ford "Hard To Beat"!!!!
ima71 trucks are older
Post by ima71 trucks are older »
yeah the 67 pedal assembly is a lot different than the 68-72.
http://www.fordification.com/clutch-brake-brackets.htm
68 F100 soon to be on an 80's 4x4 frame and 300-4spd
69 F100 300-4spd
78 F150 300-3spdOD
re: brake assembly
Yep...now you just need to get the MC pushrod (or the power booster) from a '68-up truck to match. Either that, or put your '67 bracket back in and just use the '68 bracket's hinge pin...which would probably be a lot faster and less expensive.
