transmission capacities question
farmtruckman
Post by farmtruckman »
I have a 1967 long bed with the 352 motor, so assuming it is a C6, I cannot find the basic capacity of the trans with filter change. I am figuring I will never drain the torque converter with a simple drain so how much does it hold?
Help appreciated. :?
off the top of my head. i think 13-14 quarts.
BobbyFord
Post by BobbyFord »
Between 11-12 quarts, depending on the converter and how well you drain it.
craftsman
Post by craftsman »
I think the torque converter has a drain plug, it would be best to drain it too.
If it is a c6 it holds 11 quarts if you drain the converter, probly about 5 or 6 if you don't. Put 4 in and start it run through the gears and check it till full.
