i have a 302 with a fmx behind it my question is will the tranny bolt to a 352 block and if not what all do i have to change bell housing fly wheel what thanks for any help
no you will need a different trans to bolt to a 352 . i don't think the fmx has a removable bell housing. the 302 is a small block design and the 352 is a fe bolt pattern.
I haven't tried it with an auto before but if you find a fe bellhousing make sure they are the same depth and it may work, you may have to change the torque converter and for sure the flexplate.
