\The bottom MC came from my '68 F100 that had manual drum brakes all the way around. It has two outlet ports that are of close, but not quite equal, sizes. It uses adapters on both brake lines between the lines and the MC.
My questions are:
1: What exactly is the purpose of the brass adapter fittings between the brake lines and the MC?
2: I am going to use the booster in my '69 F250CS and install power disc brakes. I have brake lines for a '68 with drum brakes, that attach fine to the bottom MC. Can I use that one?
3: Did all drum brake MC's have equal reservoirs, while disc brake MC's have unequal ones? The manual drum setup that's on my '69 now has unequal reservoirs. Could I just use THAT MC for my disc brakes? I know I need a proportioning valve, and may go back to the salvage yard to get the one from the F350, unless some one has one they want to part with.
Thanks for reading this and helping me out.
