steering column
catfishcletis
steering column
Post by catfishcletis »
i have a 1970 f 250 camper special that the steering column seized up on us. we picked up another used one out of a 69 that will work but the lower bearings appear to be out on it. is there any rebuild kits to buy also some diagrams to look at would be nice. thanks ahead of time for any information
re: steering column
You can go to the Links & Resources page for a list of vendors that can supply virtually all the parts to rebuild your column. Make sure to download or order catalogs from the first seven vendors on that list...you'll be surprised at what all you can order these days.
Then check out the Exploded-view Diagrams section, and you'll find several diagrams of the various steering columns used.
Some related links to peruse, especially helpful if you have a 3-on-the-tree, but helpful regardless:
http://www.fordification.com/steering-column.htm
http://www.fordification.com/3spd-column_01.htm
http://www.fordification.com/3spd-shorten.htm
catfishcletis
thanks for your help
