I have 15x8 rims, and I'm not sure what tires would give me the look I'm going for. I'm thinking 275/60's or 255/70's.
What size are you guys with 15x8's running and can I see pictures if you have some?
tire size help
- turk54
tire size help
Unrestored 71 Bump, 4x2 LWB, 302, 3 speed on tree, 40,000 original miles
71 Torino 500 Halo, 302, Auto
I run 235/70's... There aren't any real closeups of the tires, but I have a couple shots in my gallery.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
- turk54
And that's for sure on an 8" wide rim? That looks pretty good. I have 235/70's on the rims I'm currently running, but they are only 7" wide, I thought they would be to narrow and not look right, but yours looks good. This just might have saved me from having to buy tires. Thanksmrsnicks wrote:I run 235/70's... There aren't any real closeups of the tires, but I have a couple shots in my gallery.
Patrick
- Farmall
re: tire size help
I did a little tire coparison at the shop when I bought them. I found the the 235/75 tire had a little higher profile than the 70's, at least in the tires I looked at.
Sometimes the mind, for reasons we don't necessarily understand, just decides to go to the store for a quart of milk.
My Truck
My Truck
- MadMaxetc
235x70R15Farmall wrote:I did a little tire coparison at the shop when I bought them. I found the the 235/75 tire had a little higher profile than the 70's, at least in the tires I looked at.
235 = 235mm Width
70 = 70% of 235mm Side wall height
15 = 15" Rim
Tire Diameter = 235*.70*2/25.4+15" = 28.88"
Do yes the 75's will be a taller tire about 1"
Be sure to check the specs, as some tires have a recomended rim width range. Most are 1" less than the width of the tire. 235mm=9.25" so 8" wide rim MAX.
Dan
FORD Girl
Photobucket Pictures
FORD Girl
re: tire size help
I used to run 275/60s on my 1885 F150. They looked awesome! BUT they were almost dangerous. They floated on top of the water in the rain. I always felt like I was on the edge of control.
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
1989 Ford F150
- turk54
re: tire size help
I'll probably run my 235/70's now that I know they will work (as long as it looks ok) I will probably opt for the 275/60's when I need tires. I won't driver her much, if at all, in the rain.
