I am doing the Dakota on my 63.
I am NOT doing the MII because in order to get it to work the right way you need a bunch of custom parts. (Steering Rack extention, tubular a-arms, Custom springs or coil overs, etc...) A stock MII whent on a CAR that was half the weight of our trucks and most of that weight wasn't on the front end.
A Dakota IS a truck and has the same GVW as our trucks, so the stock parts will last a long time. If you use the rotors off a 89 then you get 5 on 5.5 bolt patern, to get that on a MII you need custom rotors and hubs.
For a show truck a MII would work fine, probly better because of the custom stuff.
For a Daily Driver a Dakota would be my pick!
Dan
FORD Girl
Photobucket Pictures
