Homemade tach housing
Ranchero50
Post by Ranchero50 »
Whittled this out over the last two nights at work. Cup started as 3" EMT and the cap was flat 16ga steel that was hand beaten on a pile of rags. I welded the cap to the cup and chucked it up on the lathe and sanded it smooth. The riser is a piece of 1.5" stainless pipe that I squeezed to an oval with the vise and a piece of 1" square stock, the programmed the mill to cut the radius' for the cup and column. The column flange is 2" EMT that was turned on the lathe and then cut on a bandsaw. Plan on either sandwiching it between the column and the dash mount of siliconing it to the column if it fits right. Took about three hours to make and about four more to figure out how to do it. I'll probally spray it with clear or powdercoat it clear if I remember to get some powder at the carlisle All Fords show next weekend.
Jamie
xxxtina63
re: Homemade tach housing
Post by xxxtina63 »
Now that is just Toooo cool! :wink: I think all trucks should have come with one of those as standard.
Ranchero50
Some more pics of the install. The column tube fit great and overall it went in very easily (much better than a hose clamp...) I'd recommend the cut up 2" EMT on the column as a tach base to anyone.
I chose to just spray it with some satin clear for now. It's nice to know that I'm shifting around 2k normally and it idles great at 600 rpm.
Jamie
wt4speed#2
Post by wt4speed#2 »
Don't really have the need for a tach ,but with a housing that sweet I could just wing it. Great job.
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
390Nut
Post by 390Nut »
You need to make some more of those! 8)
Paul
`69 F100 390 4spd driver
71Ford100
Re: re: Homemade tach housing
Post by 71Ford100 »
390Nut wrote:You need to make some more of those! 8)
Kinda what I was thinking. I bet you could make some good money if you had a assembly line set up.
Lance Peters
'72 250 4x4 project,''71 F-100 daily driver,69 F-250 4x4 Crew, '68 F-100, '68 F-250 crew under restoration, '52 Dodge 1/2 ton overload, gazillion tractors and combines
Ranchero50
Thanks for the comps, I don't know what other tachs would fit this housing. This one came out of a '84 bluebird bus via eBay for $2.25. It's 0-4000 rpm and works perfectly with the 360. Runs at 2200 RPM in fourth at 50mph with 4.10's.
Jamie
CA180
Post by CA180 »
Your truck run without keys? lol
Nice lookin pod man!
ezernut9mm
Post by ezernut9mm »
good job and nice work. :thup:
71 LONG BED
Post by 71 LONG BED »
CA180 wrote:Your truck run without keys? lol
My F350 does too! :P
But you do have to turn the tumbler to get it to run.
Awesome looking housing! I'm digging the brushed stainless look. :thup:
John Member #1549
Image Image Image
GT-Racer
Post by GT-Racer »
very cool piece.
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
kknip
Post by kknip »
Nice! How much for one? :D I really like knowing how much RPM is going on under the hood. :thup:
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
dwebster8783
Post by dwebster8783 »
you start making more of those I would buy a few for sure. Way better than those cheesy looking ones from summit.
Dan
Behind every successful man stands a surprised mother-in-law
Redcap
Post by Redcap »
That is VERY cool! Nice job! :thup: :thup:
