On my 71 with manual brakes, I've been having a problem with the left front brake tighting up on its own. I replaced the hose and the master cylinder recently and bled the lines.
I was wondering,
if the adjuster was in backwards ( the star on the wrong side for instance ) would that cause them to gradually tighten over time? Like they say to adjust them by backing up and applying the brakes. All other parts look ok so I'm grabbing at straws now.
I have to release it by cracking the connections at the master cylinder. About every 2 days. It's not getting real hot, but enough that I can keep my hand on the rim for only a few seconds.
Any suggestions appreciated. Brake fluid is gettig expensive.
