power steering system
i have a '72 f250 and a '77 f100, the 77 is getting parted out. the 72 has manual steering and the 77 has power, does anyone know if the power steering components would go into the 72 pretty easily?
- ICEMAN6166
re: power steering system
yes, its pretty easy to do.even the wiring is not that hard to deal with.
