pilot bearing removal
someone post a real easy way to remove these things something about pumping grease behind the bearing and letting that push it out. i can't remember where it was posted could someone refresh my memory on how that was done again.
spartman
Post by spartman »
What I do is to take a grease gun and pump the area behind the pilot bearing until it is level full.
Then I find a bolt or rod that is just a little smaller than the bearing hole, place it on top of the grease, then give it a good whack or two with a hammer.
This should compress the grease and force the bearing out.
ICEMAN6166
re: pilot bearing removal
Post by ICEMAN6166 »
i use grease , a 1/2 inch 3/8 drive craftsman socket and a 6" extension, and a brass hammer to hit it with.
heres someone elses idea:
http://fordtruk.com/forums/viewtopic.ph ... 140d79b30b
68F250
Post by 68F250 »
Definitely use some plastic or towels to cover everything up or else you’ll be finding flung grease in the garage for awhile. Ask me how I know. :doh:
Barry
390Nut
Post by 390Nut »
:lolprev:
Don't need to ask, I know first hand. Hence another reason to use vaseline, it doesn't have any chemicals that can be splooged into your eyes. 8)
Paul
`69 F100 390 4spd driver
