Stereo Install
- GreaseMonkey
Stereo Install
I am looking to install a modern style CD player into my truck. I have seen the DID YOU KNOW? bar talking about the Merta Volvo kit to be adapted. Has anyone ever done this? Anyone have any pix? Thanks.
1968 Ford F-250 "Puck" / 360ci V8 / C6 / Dana 60 Rear Axle (Resting in the "Big Pasture in the Sky")
1976 Ford F-250 Hi-Boy "Bubba" / 360ci FE V8 / 4spd T-18 / NP205 / Dana 44/60 Axles
http://www.fordification.com/galleries/ ... ?album=633
http://www.fordification.com/galleries/ ... ?pos=-1498
- jbrown414
re: Stereo Install
Here's a link to another thread. I don't know for sure if the pictures are of the actually bracket but it did help me.
- jor
re: Stereo Install
Here's a few photos of mine. Its mount is held in with the flexible tabs but it holds well.
jor
jor
- jbrown414
re: Stereo Install
That looks awesome. Did you just have to cut enough to make room for the cd player?
- theskytoucher
re: Stereo Install
There is no cutting involved you just pull out your old radio bend the two tabs back into the dash drill two holes and slide the radio in(after you wire it of course) FYI this was acually the question that brought me to Fordification
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
- jor
re: Stereo Install
I cut out the ears. I would recommend you bend them back if you can still slide it in. That way the purists here won't excoriate you for butchering your dash!Did you just have to cut enough to make room for the cd player?
jor
- ICEMAN6166
Re: re: Stereo Install
not to bash anyone but i am one of those. can i cut off or bend your ears back?jor wrote:I cut out the ears. I would recommend you bend them back if you can still slide it in. That way the purists here won't excoriate you for butchering your dash!Did you just have to cut enough to make room for the cd player?
jor
- jor
re: Stereo Install
If we ever have a fordification get-together, I'll be the guy with the earmuffs.
jor
jor
- Fake Name
I found bending to be the better idea. That way I could create a metal tray that anchors on the two tabs to support the stereo unit. Of course, you don't NEED that, most units are happy to just hold on by the meager support offered by the front panel, but I always hated that installation.
fn
fn
1970 F250
2011 KTM 990 ADV
2003 KTM 525EXC
2011 KTM 990 ADV
2003 KTM 525EXC
- ICEMAN6166
fordman wrote:hes one of those dash molestors. do you carry tinsnips in your rain coat?
- 69F110
- MadMaxetc
Have you seen my baseball?jor wrote:If we ever have a fordification get-together, I'll be the guy with the earmuffs.
jor
My dash has been molested already, so I plan on welding in a spot fot thr radio so that it doesn't stick out like the Plastic kits do. This will also make it harder to steel.
If I ever get a title and a warm day I could start on this thing.
(Warm days are coming, not sure on the title yet...)
Dan
FORD Girl
Photobucket Pictures
FORD Girl
