will they fit
67RED
will they fit
Post by 67RED »
steve
Life is 90% how you take it10% what you make it
i think so i would see why not. i think those are the same from 67-72 as far as fitting. they just use one bolt to hold them in per piece.
67RED
re: will they fit
Post by 67RED »
i thought they should fit. ill find out soon. thanks
steve
thats the same color my 67 has.
ICEMAN6166
re: will they fit
Post by ICEMAN6166 »
they will work
