PS Question??
jguajardotx
PS Question??
Post by jguajardotx »
I understand that the benix box was used maybe only up till 1970 so could i possibly find a 79 ps box for my 1967 f100 say at my local autozone or someplace. If i were to use say the 79 ps box would it be a direrct fit or would modifications have to be made to the steering column? Thanks.
re: PS Question??
Yes, you can get a Saginaw box at any parts store, for any similar truck up through '79, but because it's longer than the Bendix box, you will need a PS steering column which is several inches shorter.
Everything you need to know is located at the following link:
http://www.fordification.com/powersteering.htm
cghstrojan08
re: PS Question??
Post by cghstrojan08 »
Buying a new one will cost you a lot of money. I have a Bendix box out of a 1968 Ranger 360 that needs to have new seals put in it. I know it works. I put it in my truck and for some reason it set my steering wheel an inch off the column. If you want it, let me know. Are you adding power steering? If so, I have everything else. I have the box, hoses, brackets, pulleys, and a remanufactured P/S pump for adv. auto. I will give it all to you for $150 + shipping. Thanks!
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
Re: re: PS Question??
cghstrojan08 wrote:...I have a Bendix box out of a 1968 Ranger.... I put it in my truck and for some reason it set my steering wheel an inch off the column...
That can be corrected by simply loosening the firewall clamp for the column and the underdash attachment point for the column, sliding the column housing up against the wheel and then sliding the lower lock collar up against the column housing.
cghstrojan08
re: PS Question??
Did that as far as it would go and still had an inch. Thanks!
ROBERT
Member #1076
1968 F100 SWB 360
cghstrojan08
re: PS Question??
If you don't want it I will sell it to anybody who does. Thanks
ROBERT
Member #1076
1968 F100 SWB 360
those bendix setups are really wanted by the slicks 60 guys. they work great on there older trucks.
jguajardotx
re: PS Question??
My 67 has an inline 6 with three on the tree so i would like to put in a bendix and save myself the trouble of any modifications. Where do ya think i could find those seals for the box?
cghstrojan08
re: PS Question??
Well, first off, the problem is that the power steering came out of a truck with a 360. I don't know if the brackets are the same for the inline 6. I think, not for sure, that you can get a rebuild kit from advance auto. This set up probably isn't the best deal for you personally. I know though that the core charge for the Bendix box is 150 at Advance auto.
ROBERT
Member #1076
1968 F100 SWB 360
jguajardotx
re: PS Question??
RobertRobert
So would the bendix box will not fit, because of the size of your engine?
If it does fit i am still interested in buying it. i have someone who can fix seals for me. thanks let me know
engine size has nothing to do with wheather the steering box will fit or not. they are a one size fits all box. they didn't make diferent size boxes for different engines. so his will fit yours.
jguajardotx
re: PS Question??
Thanks for the info FORDMAN
So Robert if u still interested in selling your ps box let me know
thanks again
oh he meant the engine brackets for the pump. i messed up. oops. those are very different.
jguajardotx
re: PS Question??
Well ya FORDMAN but i am interested in the ps box itself. i am sure i can find a pump and brackets for my inline 6 at my local auto parts store huh???
cghstrojan08
re: PS Question??
Good luck finding the brackets for an Inline 6. The Bendix box mounted fine to my frame. I have bad cab mounts and I think that is why it was so hard for me. Some other guy is going to buy it all right now, hopefully. Don't you guys think that selling it all including the box, pump, brakets, and pulleys all for $150 + shipping is a good price. I see then go for way more than that all the time. I would like to sell it all together. If this other guy won't buy it all for what I want, the I mite just sell you the box. Then put the other stuff on ebay.
ROBERT
Member #1076
1968 F100 SWB 360
