Is this where frame questions go?
GT-Racer
Post by GT-Racer »
How many cross members do you have on a two wheel drive short bed?
I think I have one more than I should. Between where the engine perches are and where the tail shaft of tranny bolts down is another cross member. I dont think it is doing anything.... :hmm:
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
i think that is the front transmission crossmember. i don't remeber why its there. but i think it has a good purpose.
averagef250
Post by averagef250 »
On a 2wd it ties the frame togeth so the radius arm s have something solid to mount to. On a 4x4 it's inline with the spring shackles.
tynall44
re: Is this where frame questions go?
Post by tynall44 »
first time i changed m tranny i took the tranny crossmember out and never put it back that was 25 years ago still dont see what pupos it served
It's like Dustin described....and very important. You're weakening the front suspension setup by removing that completely. I'd definitely consider replacing that if it's gone.
GT-Racer
Post by GT-Racer »
So including where the engine perches are located, I should have seven cross members?
Yes, you should have seven. Take a look at the following illustration from the 1970 Body Builder's Layout Book:
http://www.fordification.com/images/FAQ/bb70/p04.gif
GT-Racer
Post by GT-Racer »
Thanks Keith. I thought maybe when the previous owner put a small block in it It might have gained a new tranny cross member. Guess not.
rjewkes
Post by rjewkes »
i know its a pain in the arse when dealing with the front bolts on a c6 pan.
Wonder if it would be safe to notch it around the trans pan area? maybe reinforce it if neccisary?
fuelly.com
Big D's 69
Post by Big D's 69 »
I don't have that one in mine. Looks like I need to round one up. But no problems as of yet with not having it. But the 514 might cause some issues. Guess we will just have to see.
