Leveling the front end
I'd like to eliminate the "nosedive" look my truck has by leveling the front end. Has anybody done this or can anyone recommend something? Should I just head down to my local supsension shop? I've got a 1972 f100 2wd.
re: Leveling the front end
I'm not sure I understand what you're asking. Are you saying the front end is sagging and you want to raise it? If so, it sounds to me like your front springs are simply wore out and it's time to replace them.
Oh, OK, you're looking to level the truck out front-to-back. You can remove a leaf or two (depending on how many your truck has now) or install lowering shackles (as long as your truck doesn't have the Flex-o-matic setup).
Or you can flip the front spring hangers on each side 180 degrees...that's good for 3"-4". However, since this will alter your pinion angle, you'll need to correct it either by relocating the spring perches or using a wedge shim between the rearend housing and spring. Here's a shot of a member's truck with the flipped bracket:
Well, I could do that, but I was looking to make the truck higher not lower. Is it possible to raise the front end to match the back end? Maybe if I used some stiffer springs up front? I'm really not sure.
That's what I'll probably do. What are the twist things?
Just swap in some F250 springs from a Camper Special or even some F350 springs...they'll raise the front end up and make it stiffer.
- 72hiboy4x4
do yourself a favor and don't use the twisty things. they are a band-aid for weak springs and will eventually ruin your springs.
Like Keith said, a good set of f-250 or 350 springs should do it for ya! or a set of 2 or 4" lift springs might do it.
2" lift springs sound like something I'm looking for. Where can I buy something like that?
- 72hiboy4x4
I haven't seen that particular type before
the twisty things I meant are made of pot metal, and screwed into the spring coils to force the springs to open/raise up.
If you're gonna do it, do it right. Get the springs, don't put a Band-aid on a broken arm.
