Stuck glovebox
Stuck glovebox
Hey All,
I've got a glovebox with a stuck door. When I got the truck, it would open, but was tricky. Had to simultaneously push the button and pull on a corner of the door. Then one day, "push pull push pull". Darnit. Wouldn't open anymore.
Is there any way of getting in there or removing the glovebox without destroying either the dashpad or the glovebox door?
Thanks,
Joel
Thanks,
Joel
re: Stuck glovebox
Yeah, that hasn't worked. The button is REALLY hard to push. All I end up with is a sore fist. Has anyone had any luck with a bent coathanger or anything? Are there any drawings of the latch around?
Thanks,
Joel
Thanks,
Joel
- 68F250
re: Stuck glovebox
Mine usually sticks when the weather turns damp. What I do is push and hold in the button while at the same time pushing in on the door. This seems to give a little more travel to get the latch into the release mode. Then, while still pushing and holding the button in, pull the door open.
Barry
- Blue Cloud
re: Stuck glovebox
I'd try to spray some penetrating oil into and around the latch. If that doesn't work, you might have to get in from underneath and take it loose. you would ruin the fiber box, but LMC has them for about $15. That's better than bending up the glove box door with a prybar and hammer!
re: Stuck glovebox
Thanks for all the ideas. If I have to get in from underneath, will I have problems with my factory AC unit? Is that hard to pull out?
Thanks,
Joel
Thanks,
Joel
re: Stuck glovebox
Push the button in. Now whack it good and hard with your fist.
It will come open.
It will come open.
- rjewkes
I always have the oposite problem mine always stick open until i wd40 the latch.
fuelly.com
fuelly.com
- studdmstr
- ExplorerNC
The PO of my 72 mounted a small half oval cabinet door handle just above the latch, as mine sticks sometimes. You can hook a finger through the handle while pushing the button and it opens right up. When I first got the truck I was going to remove it, but it turns out its pretty handy.
1972 F-100 "Explorer"
1971 F-250 "Custom" (SOLD)
1965 F-100
1966 F-100 4X4
1965 F-100
1966 F-100 4X4
I had this problem aswell. I ended up reaching around from the backside, over the cardoboard glove box, and pressing down on the latch.
I took it out and soaked it in rust penetrant and lubed it with wd40.
I did find that pushing on the door while pressing the button, helps quite a bit. The latch is rounded toward the front and flat on the back where it catches on the dash panel. When you push forward on the latch, it helps to press in the pin the holds it in. I think it was designed this way to help prevent accidental opening when barely pressing the button.
Pulling on the door helped in no way. I think it just caused the latch to hold tighter.
- ICEMAN6166
re: Stuck glovebox
do not keep hitting it or pushing it in, because most likely you are pushing the latching piece in as well, making it tighter.
push the button and use a plastic wedge so the pressure is on the inside pushing out.after you get it open, adjust the latchhook outward some.if its too loose then you can move it back a little at a time but dont go back too far or you will be stuck again.
