Steering Wheel resto
mjhaltom
Post by mjhaltom »
I picked up a three spoke wheel from a '67 to put in my '71. It had only one bad crack. I filled the crack with JB Weld and I painted it with Duplicolor flexible bumper coating. How do you think this will hold up? It looks good enough...I was wondering if anyone has tried something similar. Any feedback would be appreciated. Thanks
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
bluef250
Post by bluef250 »
Sounds like you got it handled. Been at least one thread on crack filling/wheel restoration. Some open the crack, install an epoxy or other body filler, shape, sand, epoxy again, sand, repeat if needed, prime (maybe in not the exact order), paint with 3 to 6 coats of good paint, then clear coat. I think Bondo exactly has a kit. Other also?
mjhaltom
re: Steering Wheel resto
Post by mjhaltom »
I just filled the crack with JB weld and painted with the bumper coating and so far it looks good!
1989 Ford F150
jzjames
Post by jzjames »
I would say that should do it. Let us know how the bumper coating holds up after a year.
hillbilly67
Post by hillbilly67 »
I'm going to try powdercoating mine. I have a friend that works at a shop, he says he's done similar materials. Hes baked plastic, fibreglass, wood, etc. You name it...hes tried it. I have a powdercoater and an extra wheel, so What the heck!
Made my first million.....too bad it was mistakes..not dollars! Now pass me that crescent hammer.
Jake11
Post by Jake11 »
I did exactly the same thing. Lasted about 6 Months. Looked great after
I did it. Like new. The old plastic seems to keep shrinking. I'd do it again.
Go for it. It's really nice to have a new wheel. I'm gonna pull mine and
try again with some 'marine' epoxy.
Good luck with it. Take some pic's if you can of before and after.
I'm gonna do and post them here. I could guess theres other guys
on here that are wondering about fixing theres.
I like the 3 spoke wheels better too.
Jake11
Post by Jake11 »
jzjames
Post by jzjames »
jake11 thats a good link. I like the wheels, theyre like the orig. F100
3-spoke wheels in that the spokes are not "equi-distant" 8) like the Grant wheels, (ie., the look-through part of the wheel in the straight ahead position gives you the correct view of the guages.)
jor
Post by jor »
Hillbilly,
Tell us about your powdercoater. I've done a little research on these things but they all look pretty expensive. Do you have an oven or the ambient light deal? Also, what does your rig do to your electricity bill? Thanks.
jor
Jake11
Post by Jake11 »
I'm gonna order a blue one and see how it looks. I'm from the
'metalflake' generation so I'll order one of those. Let ya know how it
looks when it turns up. :)
