lowering with beams and coils...
layedout72
Post by layedout72 »
how low can you go when it comes down to it on this stock front end? I may go mustang II but, just how low can you go? Im thinkin the drop beams and a 3 inch drop coil, and then flippin he rear and it should level things out and be plenty low for a nice look, took a little tire hopefully. Will this be too low in respect to camber and all this? I can have a little, couple degrees but I don't want it to contribute to tire wear toooo much.
SmokeyBear
Post by SmokeyBear »
maximum with a stock setup is approx. 5 inches you get 3 with drop beams and 2 with shorter coils without affecting camber. flipping the hanger in the rear gives you about 4 and shackles give you another two so you can get a 5/6 drop on stock-type suspension.
70 F-100 XLT
"Christine" Gone but not forgotten.
72 F-100 Ranger XLT
stockr
Post by stockr »
thats the route im going with
ibeams and springs in front
shackles and hangers out in back...
5/6 drop
99 COBRA-DAILY DRIVER
95 F150 EDDIE BAUER-BAGGED
94 BRONCO EDDIE BAUER-FISHN TRUCK
71 F100 SWB- HAS BEEN POSTPONED
marz68
Post by marz68 »
Hey layedout I think this one is on I beams and super notch in the rear. I like how this one look's. 8)
layedout72
bagged up front correct? I like how that looks, not layed out completely but deffinately a NICE stance.
71 LONG BED
re: lowering with beams and coils...
Post by 71 LONG BED »
Definatly like the looks of that truck!! :D :D
John Member #1549
Image Image Image
marz68
Post by marz68 »
Yeah I think it's bagged on all fours.
You can lay doors on I beams if you Z the frame and rework your body mounts and frame.
layedout72
yah, but if your gunna Z it, may as well just go mustangII with J/Y parts and new rubber pieces.
mcarlson11
Post by mcarlson11 »
I also have a question about lowering:
I have an F250 with a 78 front end, discs and all. I want to use the DJM, but I am having a hard time finding a kit for an F250, they only list it as a f100. So is there a difference? Anybody know the right kit #, or right beam #;s?
When the going gets tough, your doing something right.
green70
Post by green70 »
they should be the same,just get the ones for the 78 to match your kingpins/spindles :2cents:
green70
Post by green70 »
Djm beams w/2" coils,flip kit with c notch in the rear,front is about as low as you can go without major mods,had to cut the bump stops almost completely off in the front :2cents:
mtglass
Post by mtglass »
'73 F-250 Camper Special, 390CI 2WD
I've got the same issue, though I'm not looking for as drastic a change as some of you.
I want to know what the easiest way is to lower my front end a little? I don't carry a load often and the excess camber is wearing the outer edges of my front tires.
If I could just get it to squat a few inches that might help. How else can I adjust the camber?
Thanks
mtg
green70
Post by green70 »
you could cut your springs,start with a half coil,that should help your positive camber problem
