1979 Bed re-paint
- blue68
1979 Bed re-paint
My brother has a '79 longbed and he's wanting to prep and re-paint the inside of the bed as professional-like as he can. Painting is the easy part, but prepping is more difficult. There's probably over $150 worth of dead layers of rattle can paint back there thats been used as a "rust stop" over the past years. The top layer of that is peeling up. You can take a water hose and blast most of the top layer off, but it's still al chipped looking. He wants to get it down to the bare shiny metal and work from there. We've tried using a wire wheel attachment and all kinds of stuff, but we cant quite get through all those layers of old spray paint. Any ideas? What kind of attachment is needed to sand to shiny metal? As always, Thanks
re: 1979 Bed re-paint
rent you a bead or sand blaster, or find someone to sand blast it.
- blue68
- 71Ford100
If I was you I would wire wheel as much of the paint of as I could then use a sand blaster with fine sand (someone correct me if I'm wrong on the kind of sand). using the wire wheel first will greatly decrease the amount of sand you use and the time sandblasting. After your done just have your brother do a really through job of blowing the sand off and out of the bed. If he does a good job blowing out the sand it shouldn't affect his paint job at all.
Lance Peters
'72 250 4x4 project,''71 F-100 daily driver,69 F-250 4x4 Crew, '68 F-100, '68 F-250 crew under restoration, '52 Dodge 1/2 ton overload, gazillion tractors and combines
I'm still a firm believer in using the 3M composite stripping wheels for stuff like this...they eat through paint very easily, but it's soft enough that it won't damage sheetmetal, as long as you keep it moving. However, you're going to probably go through at least 10-15 of them....at least.
A knotted-wire wheel in an angle grinder will work too, but will take a little longer. However, it works great for getting nooks and crannies the 3M wheel can't get into.
The 3M wheel is the blue one on the right, worn down about half way. The knotted wire wheel is mounted in the angle grinder.
- blue68
- cjs_72f250
i have a related question so i wasn't sure if i should start a new thread or keep it here...so here goes:
the former owner of my truck ruined the awesome Grabber Blue paint by hand brushing white house primer paint over it.
any clever way to remove the house paint without ruining the Grabber Blue beneath it? a whire wheel or the 3M wheels will obviously eat through the blue too, right?
would scrubbing the house paint with Brake Cleaner and a rag work? that's what i've been doing to clean up some metal brackets, etc. any other ideas?
'72 F250 Explorer Camper Special
Blue68 get a big ol jar of naval jelly and let is soak into the top layers of the paint if you want.. This will soften up/dissolve the paint so it can be scraped of with a scraper, or in some cases blasted out with a pressure washer.
Just an alternative for you.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
- flyboy2610
Use a pressure washer. I wouldn't hand scrape it or you'll be repainting the whole truck.
