I have 67 f350 style side and need a new tailgate (Chain supports). Where can I get replacement lower tail light pannels The previous owner left the drivers door open while backing up. Yep, hit a fire plug or something. Where can I get new skin for the lower 1/3 or so of the door? I can find parts from LMC for F250, but no mention of F350. Are they interchainable? Lots of questions, but would appreciate any help offered.
Thanks,
pcarmack
tail light lower pannel & door skin
Knuckle Buster
- customcrewcab
re: tail light lower pannel & door skin
yep
f350 has heavier chassis
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
- 460 crew
F250 F350 have the same cabs and sheet metal.
- rjewkes
aren't all F100-
F350's 67-72 clear till 97 Have the same Body styles/sheet metal thickness within the range? I.E.
67-72, 73-79,80-86,87-96?
fuelly.com
fuelly.com
No, as the trucks got newer, the sheetmetal got thinner. This was for weight savings.
- rjewkes
I meant all 67-72's where the same and all 73-79's where like each other and such. are even the bumpsides thinner as they got newer?
fuelly.com
fuelly.com
