cleaning solution for getting grease out of carpet?
dotcentral
Post by dotcentral »
Anyone got a good product for getting old grease & stains out of carpet?
This isn't exactly truck related. I messed up the carpet in my Liberty hauling a few parts for my truck, so maybe it is.
re: cleaning solution for getting grease out of carpet?
Go to a local GM dealer and ask for a KENT product called acrosol (sp?)
If you can't find that, 3m adhesive remover might also work. Usual disclaimers apply (test on inconspicuous spot etc...)
jzjames
Post by jzjames »
If you know anyone who's got a carpet shampooer, they usually have a hand held upholstery attachment. Fill it up with any good detergent,(I use just a solution of laundry detergent and water) and repeatedly clean the greasey area. It should come out with some elbow grease.
FoMoCo
Post by FoMoCo »
Extremly hot water and clorox 2 or tide. Let the clorox 2 or tide soak first.
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
xxxtina63
Post by xxxtina63 »
I know a guy who swears by lighter fluid, the kind you use in ZIPPO lighters. Have never tried myself, for obvious reasons, but it's supposed to work.
spartman
Post by spartman »
Have you tried simple green and a scrub brush?
bigjake
Post by bigjake »
I agree spartman. I have used simple green and a brush on carpet stains and they came out.
70' F-250 cs,lwb,390
flyboy2610
Post by flyboy2610 »
A cleaner with citrus oil should work well for grease
BTW, after I've been working on my truck, I use dishsoap with citrus oil in it to clean my hands. It works as well as any commercial hand cleaner I've tried, and costs a lot less! :$$:
GTScott
Post by GTScott »
I use a great All Purpose Cleaner from Poorboy's World (they make incredible detailing supplies as well). If you mix the stuff 3:1 with warm water, let it sit a minute or two, and then shampoo it you will get great results. I have used this to remove grease and worse from my carpets.
http://www.poorboysworld.com
If you want to just try a little bit for your spot, drop me a line and I will mail you some.
-GT
67merc
Post by 67merc »
My dad gave me some great stuff called Purple Power. Not sure if that's the real name or not. But he got it from a guy that does detailing. It's amazing! It's an industrial degreaser. I used it under my hood and took off all the grime with the Purple Power and a power washer. No Scrubbing. Any way the old man says it works to get the grease out of his shop clothes too. If you could find it I'd try it.
Becca
bumt72
Post by bumt72 »
I like Goof Off, use the stuff for all kinds of cleaning like that, you can find it at wall mart and K-mart
Kep
1972 F250 Da Big Ugly Man TruckDa BUMT
1961 F100 Stepside (Father/Daughter Project)UnNamed
cooltoolguy
Post by cooltoolguy »
my local dry cleaner gave me some of the solution he uses, it took out stuff i didnt even know was in the rug.
72 Ford F-350, 2WD, 4 speed 360, Dump truck
76 Ford F-350, 2WD, Cab and Chassis <--gone
ratfink
Post by ratfink »
I have used electrical contact cleaner quite a few times before.
Spray it on and blot it up dont rub it, it will smear the stain.
Ratfink
Dennis
1968 F100 Ranger 390/ C6 (Mine again)
2008 Toyota FJ Cruiser Sandstorm
2007 3500 4X4 Dodge Cummins
Idleness is the mother of all vices.
